Saltar al contenido principal
Disassembling Sony Ericsson W580i Back Cover
Qué necesitas
  1. Disassembling Sony Ericsson W580i Back Cover, Battery: paso 1, imagen 1 de 3 Disassembling Sony Ericsson W580i Back Cover, Battery: paso 1, imagen 2 de 3 Disassembling Sony Ericsson W580i Back Cover, Battery: paso 1, imagen 3 de 3
    • Hold the phone with the screen facing down. Push the back cover firmly down and slide it towards you.
    • The panel will slide down about 2mm.
    • Lift the panel away from the phone.
  2. Disassembling Sony Ericsson W580i Back Cover: paso 2, imagen 1 de 1
    • Lift the battery out from the bottom edge.
  3. Disassembling Sony Ericsson W580i Back Cover, Back Cover: paso 3, imagen 1 de 1
    • Insert the edge of an opening tool between the back cover and the phone body on the top edge (not to be confused with the edge where the phone slides).
    • Pry the back case off of the phone working your way around the edges until the panel is freed from the phone.
    • Be careful when pulling the spudger down the side by the charging port. The plastic cover may bend or snap.
  4. Disassembling Sony Ericsson W580i Back Cover: paso 4, imagen 1 de 3 Disassembling Sony Ericsson W580i Back Cover: paso 4, imagen 2 de 3 Disassembling Sony Ericsson W580i Back Cover: paso 4, imagen 3 de 3
    • While removing the back cover do not lose the power button. It is held in place by the back cover and may fall off during removal.
    • Pull the back cover away from the phone.
    • Remove the power button if it has not already come off.
Conclusión
4 personas más completaron esta guía.
Cherie
Miembro Desde 10/09/11
220 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 5-31, Amido Fall 2011 Miembro de Cal Poly, Team 5-31, Amido Fall 2011
CPSU-AMIDO-F11S5G31
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 45
Todo El Tiempo: 8,770
