Saltar al contenido principal
Disassembling Sony Ericsson W200i Core
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Disassembling Sony Ericsson W200i Core, Disassembling Sony Ericsson W200i Battery: paso 1, imagen 1 de 2 Disassembling Sony Ericsson W200i Core, Disassembling Sony Ericsson W200i Battery: paso 1, imagen 2 de 2
    • Slide the battery cover up and off the phone.
  2. Disassembling Sony Ericsson W200i Core: paso 2, imagen 1 de 2 Disassembling Sony Ericsson W200i Core: paso 2, imagen 2 de 2
    • Pop the battery out of its slot by lifting it up.
  3. Disassembling Sony Ericsson W200i Core, Front Case: paso 3, imagen 1 de 3 Disassembling Sony Ericsson W200i Core, Front Case: paso 3, imagen 2 de 3 Disassembling Sony Ericsson W200i Core, Front Case: paso 3, imagen 3 de 3
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Disassembling Sony Ericsson W200i Core, Core: paso 4, imagen 1 de 2 Disassembling Sony Ericsson W200i Core, Core: paso 4, imagen 2 de 2
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
  5. Disassembling Sony Ericsson W200i Core: paso 5, imagen 1 de 3 Disassembling Sony Ericsson W200i Core: paso 5, imagen 2 de 3 Disassembling Sony Ericsson W200i Core: paso 5, imagen 3 de 3
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
Conclusión
Emily Prescott
Miembro Desde 01/10/11
531 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 14-10, Forte Winter 2011 Miembro de Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 506
