Saltar al contenido principal
Disassembling Sony Cyber-shot DSC-W5 Back Cover
Qué necesitas
  1. Disassembling Sony Cyber-shot DSC-W5 Back Cover, Back Cover: paso 1, imagen 1 de 1
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Disassembling Sony Cyber-shot DSC-W5 Back Cover: paso 2, imagen 1 de 2 Disassembling Sony Cyber-shot DSC-W5 Back Cover: paso 2, imagen 2 de 2
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Disassembling Sony Cyber-shot DSC-W5 Back Cover: paso 3, imagen 1 de 2 Disassembling Sony Cyber-shot DSC-W5 Back Cover: paso 3, imagen 2 de 2
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
Conclusión
2 personas más completaron esta guía.
Thomas
Miembro Desde 04/14/10
133 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 15-50, Garner Spring 2010 Miembro de Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 5,611
