Introducción
The lithium-ion battery is needed in order to provide power to the Snapfon ez One.
Partes
No se requieren partes.
  1. Make sure the phone is turned off by pressing the power off button ensuring no data is lost.
    • Make sure the phone is turned off by pressing the power off button ensuring no data is lost.
    • Remove the back battery cover by sliding it downward and pushing simultaneously.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Using either your thumb or the opening tools, remove the battery by prying you in the direction of the arrow
    • Using either your thumb or the opening tools, remove the battery by prying you in the direction of the arrow
    • If removing battery is for the replacement of a new battery make sure to properly dispose of the old battery at a recycling center.
Conclusión
You can now insert the new battery in the same manner as when you disassembled it. Now, to reassemble your device, follow these instructions in reverse order.
John Bender
Miembro Desde 26/03/14
822 Reputación
8 Guías creadas
Equipo
Clemson, Team 6-5, Benson Spring 2014 Miembro de Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Miembros
16 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 11
Todo El Tiempo: 354
