Saltar al contenido principal
Disassembling Sirius Stiletto 100 Front Cover
Qué necesitas
  1. Disassembling Sirius Stiletto 100 Front Cover, Front Cover: paso 1, imagen 1 de 2 Disassembling Sirius Stiletto 100 Front Cover, Front Cover: paso 1, imagen 2 de 2
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Disassembling Sirius Stiletto 100 Front Cover: paso 2, imagen 1 de 2 Disassembling Sirius Stiletto 100 Front Cover: paso 2, imagen 2 de 2
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Disassembling Sirius Stiletto 100 Front Cover: paso 3, imagen 1 de 3 Disassembling Sirius Stiletto 100 Front Cover: paso 3, imagen 2 de 3 Disassembling Sirius Stiletto 100 Front Cover: paso 3, imagen 3 de 3
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
Conclusión
Trey
Miembro Desde 03/09/12
80 Reputación
2 Guías creadas
Equipo
Clemson, Team 2-1, Benson Spring 2012 Miembro de Clemson, Team 2-1, Benson Spring 2012
CLEM-BENSON-S12S2G1
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 1,573
