Saltar al contenido principal
Disassembling Sanyo SCP-8100 Back Panel
Qué necesitas
  1. Disassembling Sanyo SCP-8100 Back Panel, Battery: paso 1, imagen 1 de 3 Disassembling Sanyo SCP-8100 Back Panel, Battery: paso 1, imagen 2 de 3 Disassembling Sanyo SCP-8100 Back Panel, Battery: paso 1, imagen 3 de 3
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Disassembling Sanyo SCP-8100 Back Panel, Back Panel: paso 2, imagen 1 de 2 Disassembling Sanyo SCP-8100 Back Panel, Back Panel: paso 2, imagen 2 de 2
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Disassembling Sanyo SCP-8100 Back Panel: paso 3, imagen 1 de 1
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Disassembling Sanyo SCP-8100 Back Panel: paso 4, imagen 1 de 2 Disassembling Sanyo SCP-8100 Back Panel: paso 4, imagen 2 de 2
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  5. Disassembling Sanyo SCP-8100 Back Panel: paso 5, imagen 1 de 3 Disassembling Sanyo SCP-8100 Back Panel: paso 5, imagen 2 de 3 Disassembling Sanyo SCP-8100 Back Panel: paso 5, imagen 3 de 3
    • While removing the back panel, take out the rubber cover on each side.
Conclusión
Yemane
Miembro Desde 04/13/13
11 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-41, Amido Spring 2013 Miembro de Cal Poly, Team 10-41, Amido Spring 2013
CPSU-AMIDO-S13S10G41
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 387
