Saltar al contenido principal
Disassembling Sanyo Katana Eclipse X's Back Panel
Qué necesitas
  1. Disassembling Sanyo Katana Eclipse X's Back Panel, Back Panel: paso 1, imagen 1 de 2 Disassembling Sanyo Katana Eclipse X's Back Panel, Back Panel: paso 1, imagen 2 de 2
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Disassembling Sanyo Katana Eclipse X's Back Panel: paso 2, imagen 1 de 1
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
Conclusión
Thomas Scaggs
Miembro Desde 10/15/12
209 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 289
