Saltar al contenido principal
Disassembling Samsung TFT Color YP-T7J USB Connector Dock
Qué necesitas
  1. Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Back Cover: paso 1, imagen 1 de 2 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Back Cover: paso 1, imagen 2 de 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 2, imagen 1 de 2 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 2, imagen 2 de 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 3, imagen 1 de 3 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 3, imagen 2 de 3 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 3, imagen 3 de 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Battery: paso 4, imagen 1 de 2 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, The Battery: paso 4, imagen 2 de 2
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 5, imagen 1 de 2 Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 5, imagen 2 de 2
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
  6. Disassembling Samsung TFT Color YP-T7J USB Connector Dock, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 6, imagen 1 de 3 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 6, imagen 2 de 3 Disassembling Samsung TFT Color YP-T7J USB Connector Dock, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 6, imagen 3 de 3
    • Once the battery has been removed you can see the motherboard.
    • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
    • The USB connector can now be taken off of the device.
Conclusión
Dylan Peters
Miembro Desde 10/18/13
409 Reputación
4 Guías creadas
Equipo
Clemson, Team 14-8, Benson Fall 2013 Miembro de Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 574
