Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Partes
No se especificaron partes.
  1. Remove the 2 screws on the back cover using a Phillips head #0 screwdriver. Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Remove the screw on each side of the device using a Phillips head screwdriver. Remove the screw on each side of the device using a Phillips head screwdriver.
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws. Gently pry open the back cover. Insert the plastic opening tool in between the cover joints. Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Kits de Reparación de Pantalla LCD de iPhone
    La opción de presupuesto, cubierta por nuestra garantía de por vida.
    Compra kits
    Reduce los costos de reparación, no la calidad.
    Compra kits
  5. Using the philips screwdriver, remove the two screws on the mother board. Using the philips screwdriver, remove the two screws on the mother board.
    • Using the philips screwdriver, remove the two screws on the mother board.
  6. Place the pry tool in-between the front cover and mother board. Gently separate the front cover. Gently separate the front cover.
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  7. After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  8. CAUTION: Do not rip the electric ribbon from the mother board. Carefully flip up the plastic lip that holds the electric ribbon to the board.
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
Conclusión
Una persona más ha completado esta guía.
Jason Farr
Miembro Desde 21/10/13
353 Reputación
3 Guías creadas
Equipo
Clemson, Team 14-8, Benson Fall 2013 Miembro de Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 156
