Saltar al contenido principal
Samsung SPH-A760 Speakers Replacement
Qué necesitas
  1. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Battery: paso 1, imagen 1 de 2 Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Battery: paso 1, imagen 2 de 2
    • Push open the latch and remove the battery.
  2. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Antenna: paso 2, imagen 1 de 2 Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Antenna: paso 2, imagen 2 de 2
    • Twist off the antenna.
    • Pop off the transparent cylinder.
  3. Samsung SPH-A760 Speakers Replacement, Logic Board: paso 3, imagen 1 de 1
    • Remove the five screws as shown.
  4. Samsung SPH-A760 Speakers Replacement: paso 4, imagen 1 de 1
    • Carefully pry the back plate off.
  5. Samsung SPH-A760 Speakers Replacement: paso 5, imagen 1 de 2 Samsung SPH-A760 Speakers Replacement: paso 5, imagen 2 de 2
    • Carefully detach golden screen connector.
  6. Samsung SPH-A760 Speakers Replacement: paso 6, imagen 1 de 2 Samsung SPH-A760 Speakers Replacement: paso 6, imagen 2 de 2
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  7. Samsung SPH-A760 Speakers Replacement: paso 7, imagen 1 de 2 Samsung SPH-A760 Speakers Replacement: paso 7, imagen 2 de 2
    • Place the logic board on a clean tray.
  8. Samsung SPH-A760 Speakers Replacement, Speakers: paso 8, imagen 1 de 2 Samsung SPH-A760 Speakers Replacement, Speakers: paso 8, imagen 2 de 2
    • Remove the hinge on the phone.
    • Put pressure on the spring with the screwdriver to unhinge phone.
    • Make sure to pull the gold wire through, don't let it rip.
  9. Samsung SPH-A760 Speakers Replacement: paso 9, imagen 1 de 3 Samsung SPH-A760 Speakers Replacement: paso 9, imagen 2 de 3 Samsung SPH-A760 Speakers Replacement: paso 9, imagen 3 de 3
    • Remove the four screws as shown
    • Use the spudger to pry it open, excessive force may be necessary.
  10. Samsung SPH-A760 Speakers Replacement: paso 10, imagen 1 de 3 Samsung SPH-A760 Speakers Replacement: paso 10, imagen 2 de 3 Samsung SPH-A760 Speakers Replacement: paso 10, imagen 3 de 3
    • Remove the three screws that hold the big speaker
    • Caution: The wires are attached to the screen and should be removed with care.
Conclusión
David
Miembro Desde 04/19/10
25 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 10-43, Garner Spring 2010 Miembro de Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,931
