Introducción
How to remove all speakers on the phone.
  1. Push open the latch and remove the battery.
    • Push open the latch and remove the battery.
  2. Twist off the antenna.
    • Twist off the antenna.
    • Pop off the transparent cylinder.
    • Remove the five screws as shown.
    • Carefully pry the back plate off.
    • Carefully detach golden screen connector.
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
    • Place the logic board on a clean tray.
    • Remove the hinge on the phone.
      • Put pressure on the spring with the screwdriver to unhinge phone.
    • Make sure to pull the gold wire through, don't let it rip.
    • Remove the four screws as shown
    • Use the spudger to pry it open, excessive force may be necessary.
    • Remove the three screws that hold the big speaker
      • Caution: The wires are attached to the screen and should be removed with care.
Conclusión
doconnor
Miembro Desde 19/04/10
25 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 10-43, Garner Spring 2010 Miembro de Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 Miembros
12 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,836
