Saltar al contenido principal
Disassembling Samsung Gravity SGH-T459 Keypad
Qué necesitas
  1. Disassembling Samsung Gravity SGH-T459 Keypad, Disassembling Samsung Gravity SGH-T459  Back Cover: paso 1, imagen 1 de 1
    • Press and hold the End key to power down the cell phone.
    • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
  2. Disassembling Samsung Gravity SGH-T459 Keypad, Disassembling Samsung Gravity SGH-T459  Battery: paso 2, imagen 1 de 1
    • Gently lift up and remove battery with your fingers in the direction of the arrows.
  3. Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: paso 3, imagen 1 de 3 Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: paso 3, imagen 2 de 3 Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: paso 3, imagen 3 de 3
    • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
    • Slide the phone open.
    • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
    • Gently lift and remove the rear case from the cell phone.
  4. Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: paso 4, imagen 1 de 3 Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: paso 4, imagen 2 de 3 Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: paso 4, imagen 3 de 3
    • Gently remove the two button contacts with your fingers.
    • Use a plastic prying tool to pry the keypad away from the circuit board.
    • Use tweezers to gently remove the keypad.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 12
Todo El Tiempo: 746
