Saltar al contenido principal
Disassembling Samsung Gravity SGH-T459 Rear Case
Qué necesitas
  1. Disassembling Samsung Gravity SGH-T459  Rear Case, Disassembling Samsung Gravity SGH-T459  Back Cover: paso 1, imagen 1 de 1
    • Press and hold the End key to power down the cell phone.
    • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
  2. Disassembling Samsung Gravity SGH-T459  Rear Case, Disassembling Samsung Gravity SGH-T459  Battery: paso 2, imagen 1 de 1
    • Gently lift up and remove battery with your fingers in the direction of the arrows.
  3. Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: paso 3, imagen 1 de 3 Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: paso 3, imagen 2 de 3 Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: paso 3, imagen 3 de 3
    • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
    • Slide the phone open.
    • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
    • Gently lift and remove the rear case from the cell phone.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 13
Todo El Tiempo: 367
