Saltar al contenido principal
Disassembling Samsung Galaxy S Blaze Whole Device
Qué necesitas
  1. Disassembling Samsung Galaxy S Blaze Whole Device, Disassembling Samsung Galaxy S Blaze Whole Device: paso 1, imagen 1 de 1
    • Remove the back plate.
  2. Disassembling Samsung Galaxy S Blaze Whole Device: paso 2, imagen 1 de 1
    • Remove the battery from the device.
  3. Disassembling Samsung Galaxy S Blaze Whole Device: paso 3, imagen 1 de 2 Disassembling Samsung Galaxy S Blaze Whole Device: paso 3, imagen 2 de 2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Disassembling Samsung Galaxy S Blaze Whole Device: paso 4, imagen 1 de 1
    • Remove the frame from the phone by using the blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Disassembling Samsung Galaxy S Blaze Whole Device: paso 5, imagen 1 de 1
    • The volume rocker is attached to the frame by two plastic prongs.
    • Unhook the prongs from the frame and remove the volume rocker.
  6. Disassembling Samsung Galaxy S Blaze Whole Device: paso 6, imagen 1 de 1
    • The SD card slot is held in place by a small tab.
    • Unhook the tab of the SD card slot from the frame of the phone.
  7. Disassembling Samsung Galaxy S Blaze Whole Device: paso 7, imagen 1 de 1
    • The power button is attached to the phone with two prongs.
    • Unhook the prongs of the power button from the frame of the phone.
  8. Disassembling Samsung Galaxy S Blaze Whole Device: paso 8, imagen 1 de 3 Disassembling Samsung Galaxy S Blaze Whole Device: paso 8, imagen 2 de 3 Disassembling Samsung Galaxy S Blaze Whole Device: paso 8, imagen 3 de 3
    • 4 ribbon cable connectors hold the motherboard to the phone.
    • The first 3 are all on one side.
    • Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
  9. Disassembling Samsung Galaxy S Blaze Whole Device: paso 9, imagen 1 de 1
    • Flip the motherboard over to access the last ribbon cable connector.
    • Unlatch the final ribbon cable connector from the phone.
    • Remove the motherboard from the phone.
  10. Disassembling Samsung Galaxy S Blaze Whole Device: paso 10, imagen 1 de 1
    • All of the parts are seen here.
Conclusión
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
2 personas más completaron esta guía.
Jake Best
Miembro Desde 03/05/15
261 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 723
