Saltar al contenido principal
Disassembling Samsung Galaxy Ace Logic Board
Qué necesitas
  1. Disassembling Samsung Galaxy Ace Logic Board, Logic Board: paso 1, imagen 1 de 2 Disassembling Samsung Galaxy Ace Logic Board, Logic Board: paso 1, imagen 2 de 2
    • Remove the battery cover and the battery
  2. Disassembling Samsung Galaxy Ace Logic Board: paso 2, imagen 1 de 2 Disassembling Samsung Galaxy Ace Logic Board: paso 2, imagen 2 de 2
    • Remove the 7 silver screws with a Phillips #000 screw driver.
    • Sometimes the green one could be a little difficult. Use a tweezer for get it out.
  3. Disassembling Samsung Galaxy Ace Logic Board: paso 3, imagen 1 de 3 Disassembling Samsung Galaxy Ace Logic Board: paso 3, imagen 2 de 3 Disassembling Samsung Galaxy Ace Logic Board: paso 3, imagen 3 de 3
    • Lift gently the back cover from the screen assembly from the bottom.
  4. Disassembling Samsung Galaxy Ace Logic Board: paso 4, imagen 1 de 2 Disassembling Samsung Galaxy Ace Logic Board: paso 4, imagen 2 de 2
    • Use a flat tweezer for take off the flexible on/off button from the frame.
    • Be careful, the flexible is very delicate; it could be cut if you go too fast.
  5. Disassembling Samsung Galaxy Ace Logic Board: paso 5, imagen 1 de 3 Disassembling Samsung Galaxy Ace Logic Board: paso 5, imagen 2 de 3 Disassembling Samsung Galaxy Ace Logic Board: paso 5, imagen 3 de 3
    • Use a flat tweezer and take off gently Flexible volume button from the left side.
    • Do the same for the right side.
    • Then lift the flex slowly, if you go fast you may cut the cable.
  6. Disassembling Samsung Galaxy Ace Logic Board: paso 6, imagen 1 de 1
    • Lift the microphone from the logic board.
  7. Disassembling Samsung Galaxy Ace Logic Board: paso 7, imagen 1 de 3 Disassembling Samsung Galaxy Ace Logic Board: paso 7, imagen 2 de 3 Disassembling Samsung Galaxy Ace Logic Board: paso 7, imagen 3 de 3
    • Lift the sensor/earpiece cable with the opening tool.
    • Don't force, you may damage the soldering.
  8. Disassembling Samsung Galaxy Ace Logic Board: paso 8, imagen 1 de 3 Disassembling Samsung Galaxy Ace Logic Board: paso 8, imagen 2 de 3 Disassembling Samsung Galaxy Ace Logic Board: paso 8, imagen 3 de 3
    • Lift the logic board from the right side.
    • Use the removal tool to unplug the display cable from the logic board.
    • You can now separate the Logic board from the display assembly.
  9. Disassembling Samsung Galaxy Ace Logic Board: paso 9, imagen 1 de 2 Disassembling Samsung Galaxy Ace Logic Board: paso 9, imagen 2 de 2
    • Use the removal tool to unclip the camera module from the Logic board.
  10. Disassembling Samsung Galaxy Ace Logic Board: paso 10, imagen 1 de 3 Disassembling Samsung Galaxy Ace Logic Board: paso 10, imagen 2 de 3 Disassembling Samsung Galaxy Ace Logic Board: paso 10, imagen 3 de 3
    • Use the removal tool or a spudger to unplug speaker module cable
    • And separate the speaker module from Logic board.
    • Be caution, the module is fixed by plastic teeth to the Logic board. Don't force, just make little wave-movements and the speaker comes on his own.
  11. Disassembling Samsung Galaxy Ace Logic Board: paso 11, imagen 1 de 1
    • Now you can work with the Logic board.
Conclusión
34 personas más completaron esta guía.
finster
Miembro Desde 08/17/11
1,986 Reputación
1 Guía escrita
2 comentarios
Thanks for the post. This is really Helpful
Dave Dayanan - Contestar
im curently selling one thx to you
Kyle at work - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 26,716
