Saltar al contenido principal
Disassembling SKIL 4235 Jigsaw Base plate
Qué necesitas
  1. Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: paso 1, imagen 1 de 3 Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: paso 1, imagen 2 de 3 Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: paso 1, imagen 3 de 3
    • Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide.
  2. Disassembling SKIL 4235 Jigsaw Base plate: paso 2, imagen 1 de 1
    • Using two hands grip both side of the saw and lay on side.
  3. Disassembling SKIL 4235 Jigsaw Base plate: paso 3, imagen 1 de 1
    • With bottom of the base plate visible, identify one M4 screw circled in red and remove with Phillips screwdriver (some models have flathead screw, as pictured, and require flathead screwdriver).
  4. Disassembling SKIL 4235 Jigsaw Base plate: paso 4, imagen 1 de 1
    • After removing M4 screw, remove the base plate and place to the side. Don't forget to replace the M4 screw near the base plate during re-installation.
Conclusión
Una persona más ha completado esta guía.
Adam Cardoso
Miembro Desde 11/12/13
357 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 31
Todo El Tiempo: 2,993
