Saltar al contenido principal
Disassembling Qualcomm QCP-2760 Rear Backing
Qué necesitas
  1. Disassembling Qualcomm QCP-2760 Rear Backing, Battery: paso 1, imagen 1 de 1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: paso 2, imagen 1 de 2 Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: paso 2, imagen 2 de 2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
Conclusión
Xavier
Miembro Desde 10/02/14
313 Reputación
3 Guías creadas
Equipo
Ohio State, Team 1-4, Buehl Fall 2014 Miembro de Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 210
