Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
These instructions will show you the very first step into accessing the inside of the Apple G5.
  1. To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Remove all the cables, including the power cables before opening the unit.
    • Remove all the cables, including the power cables before opening the unit.
  3. Lift the tab to unlock the side panel. The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Remove the air deflector (the clear plastic cover) by pulling on the handle. Remove the air deflector (the clear plastic cover) by pulling on the handle. Remove the air deflector (the clear plastic cover) by pulling on the handle.
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
Linea de Meta
2 personas más completaron esta guía.
Jessica Chaidez
Miembro Desde 13/01/10
7,674 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-8, Forte Winter 2010 Miembro de Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 3,446
