Introducción
This guide details the removal of the DVD-ROM from the disc drive tray.
Qué necesitas
Pull on outer latch.
Lower door until it is level with your work surface.
Removing the faceplate.
On the inside of the case, find the two plastic tabs.
While depressing the tabs, remove the faceplate by pulling and rotating outward.
Remove DVD drive from the drive bay.
Lift the two metal tabs on the back of the shielding and remove.
Remove the four screws on the bottom of the drive with the Phillips #1 screwdriver.
Slide out DVD drive.
11 personas más completaron esta guía.
