Saltar al contenido principal
Disassembling Power Mac G4 M5183 DVD-ROM Drive
Qué necesitas
  1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: paso 1, imagen 1 de 2 Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: paso 1, imagen 2 de 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: paso 2, imagen 1 de 2 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: paso 2, imagen 2 de 2
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  3. Disassembling Power Mac G4 M5183 DVD-ROM Drive: paso 3, imagen 1 de 1
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  4. Disassembling Power Mac G4 M5183 DVD-ROM Drive: paso 4, imagen 1 de 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive: paso 4, imagen 2 de 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive: paso 4, imagen 3 de 3
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
  5. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: paso 5, imagen 1 de 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: paso 5, imagen 2 de 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: paso 5, imagen 3 de 3
    • Remove DVD drive from the drive bay.
    • Lift the two metal tabs on the back of the shielding and remove.
    • Remove the four screws on the bottom of the drive with the Phillips #1 screwdriver.
    • Slide out DVD drive.
Conclusión
11 personas más completaron esta guía.
Stephen Scruggs
Miembro Desde 01/20/10
2,238 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 13-24, Maness Winter 2010 Miembro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Miembros
25 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 28
Todo El Tiempo: 11,144
