Introducción
How to replace the LCD screen if it is broken or cracked.
Partes
No se requieren partes.
  1. Locate the battery cover on the bottom of the camera.
    • Locate the battery cover on the bottom of the camera.
  2. Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
    • Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
  3. Remove the batteries from the camera.
    • Remove the batteries from the camera.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
    • Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
  6. Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  7. Locate the black plastic strip under the screen above the white plastic strip.
    • Locate the black plastic strip under the screen above the white plastic strip.
  8. Pull up both sides of the black piece up about a mm.
    • Pull up both sides of the black piece up about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
Conclusión
Dani
Miembro Desde 24/06/10
21 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 3-3, Johann Summer 2010 Miembro de Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Miembros
7 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,521
