Introducción
Removing the casing is necessary to replace the LCD screen or the buttons.
Partes
No se requieren partes.
  1. Locate the battery cover on the bottom of the camera.
    • Locate the battery cover on the bottom of the camera.
  2. Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
    • Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the batteries from the camera.
    • Remove the batteries from the camera.
  5. Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
    • Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
  6. Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
Conclusión
Dani
Miembro Desde 24/06/10
21 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 3-3, Johann Summer 2010 Miembro de Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 4
Todo El Tiempo: 1,449
