Saltar al contenido principal
Disassembling Polaroid a520 Battery Cover
Qué necesitas
  1. Disassembling Polaroid a520 Battery Cover, Battery: paso 1, imagen 1 de 2 Disassembling Polaroid a520 Battery Cover, Battery: paso 1, imagen 2 de 2
    • Place your thumb on the battery cover and push left towards the arrow.
    • The cover will release and pop open.
  2. Disassembling Polaroid a520 Battery Cover: paso 2, imagen 1 de 1
    • Remove the batteries from the camera.
  3. Disassembling Polaroid a520 Battery Cover, Casing: paso 3, imagen 1 de 1
    • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
    • This will release the front and back casings.
  4. Disassembling Polaroid a520 Battery Cover: paso 4, imagen 1 de 1
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  5. Disassembling Polaroid a520 Battery Cover, LCD Screen: paso 5, imagen 1 de 1
    • Under the screen, locate the black plastic strip that sits above the white plastic strip.
  6. Disassembling Polaroid a520 Battery Cover: paso 6, imagen 1 de 1
    • Pull both sides of the black piece upward-about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
  7. Disassembling Polaroid a520 Battery Cover, Battery Cover: paso 7, imagen 1 de 1
    • Remove the four 6mm screws from the inner casing using a Phillips #00 screwdriver.
  8. Disassembling Polaroid a520 Battery Cover: paso 8, imagen 1 de 1
    • Pull the inner casing off. If all the screws are out, the casing will come off easily.
  9. Disassembling Polaroid a520 Battery Cover: paso 9, imagen 1 de 2 Disassembling Polaroid a520 Battery Cover: paso 9, imagen 2 de 2
    • Use the pointed end of a spudger to push the push-pin partly through.
  10. Disassembling Polaroid a520 Battery Cover: paso 10, imagen 1 de 1
    • From the other side pull the pin all the way out. The battery cover will fall off.
  11. Disassembling Polaroid a520 Battery Cover: paso 11, imagen 1 de 1
    • The spring can now be pulled out of its resting position/holes.
    • Once removed, be sure to set the spring somewhere you won't lose it.
Conclusión
Dani
Miembro Desde 06/24/10
21 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 3-3, Johann Summer 2010 Miembro de Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 2,191
