Saltar al contenido principal
Disassembling Philips Portable Speaker SBA1610 37 Battery Casing
Qué necesitas
  1. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing, Battery Casing: paso 1, imagen 1 de 1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: paso 2, imagen 1 de 3 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: paso 2, imagen 2 de 3 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: paso 2, imagen 3 de 3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: paso 3, imagen 1 de 2 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: paso 3, imagen 2 de 2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
Conclusión
Una persona más ha completado esta guía.
Equipo
Clemson, Team 14-4, Benson Fall 2013 Miembro de Clemson, Team 14-4, Benson Fall 2013
CLEM-BENSON-F13S14G4
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 4,717
