Saltar al contenido principal
Disassembling Pentax Optio S4i Lens Assembly
Qué necesitas
  1. Disassembling Pentax Optio S4i Lens Assembly, Front and Back Cover: paso 1, imagen 1 de 2 Disassembling Pentax Optio S4i Lens Assembly, Front and Back Cover: paso 1, imagen 2 de 2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Disassembling Pentax Optio S4i Lens Assembly: paso 2, imagen 1 de 1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Disassembling Pentax Optio S4i Lens Assembly: paso 3, imagen 1 de 2 Disassembling Pentax Optio S4i Lens Assembly: paso 3, imagen 2 de 2
    • Carefully pull the back of casing away from the front.
  4. Disassembling Pentax Optio S4i Lens Assembly: paso 4, imagen 1 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 4, imagen 2 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 4, imagen 3 de 3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Disassembling Pentax Optio S4i Lens Assembly: paso 5, imagen 1 de 2 Disassembling Pentax Optio S4i Lens Assembly: paso 5, imagen 2 de 2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
  6. Disassembling Pentax Optio S4i Lens Assembly, LCD: paso 6, imagen 1 de 2 Disassembling Pentax Optio S4i Lens Assembly, LCD: paso 6, imagen 2 de 2
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
  7. Disassembling Pentax Optio S4i Lens Assembly: paso 7, imagen 1 de 2 Disassembling Pentax Optio S4i Lens Assembly: paso 7, imagen 2 de 2
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in red is a shorter black 2.00mm Phillips #00 screw
  8. Disassembling Pentax Optio S4i Lens Assembly: paso 8, imagen 1 de 1
    • Pull the cover plate off for the two power cord jacks.
  9. Disassembling Pentax Optio S4i Lens Assembly: paso 9, imagen 1 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 9, imagen 2 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 9, imagen 3 de 3
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
  10. Disassembling Pentax Optio S4i Lens Assembly: paso 10, imagen 1 de 1
    • Remove the orange tape on top of the SD cardholder.
  11. Disassembling Pentax Optio S4i Lens Assembly: paso 11, imagen 1 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 11, imagen 2 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 11, imagen 3 de 3
    • Open the battery cover and lift plastic piece off.
  12. Disassembling Pentax Optio S4i Lens Assembly: paso 12, imagen 1 de 1
    • Remove tape on left side of camera.
  13. Disassembling Pentax Optio S4i Lens Assembly: paso 13, imagen 1 de 1
    • Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
  14. Disassembling Pentax Optio S4i Lens Assembly: paso 14, imagen 1 de 1
    • Remove top left LCD bracket.
    • This is a small piece, be careful not to lose it.
  15. Disassembling Pentax Optio S4i Lens Assembly: paso 15, imagen 1 de 2 Disassembling Pentax Optio S4i Lens Assembly: paso 15, imagen 2 de 2
    • Push down bottom left LCD bracket to release the LCD from grip.
  16. Disassembling Pentax Optio S4i Lens Assembly: paso 16, imagen 1 de 1
    • Gently lift up LCD screen.
  17. Disassembling Pentax Optio S4i Lens Assembly: paso 17, imagen 1 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 17, imagen 2 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 17, imagen 3 de 3
    • Slowly pull LCD screen to the left to remove it from the other grips.
    • BEWARE: The LCD screen is attached to the logic board by two wires at the bottom.
  18. Disassembling Pentax Optio S4i Lens Assembly, Lens Assembly: paso 18, imagen 1 de 3 Disassembling Pentax Optio S4i Lens Assembly, Lens Assembly: paso 18, imagen 2 de 3 Disassembling Pentax Optio S4i Lens Assembly, Lens Assembly: paso 18, imagen 3 de 3
    • Lift up tape slightly on both sides of speaker.
  19. Disassembling Pentax Optio S4i Lens Assembly: paso 19, imagen 1 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 19, imagen 2 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 19, imagen 3 de 3
    • Use the pointed end of a spudger to lift up brackets.
    • Lift speaker cover out.
  20. Disassembling Pentax Optio S4i Lens Assembly: paso 20, imagen 1 de 1
    • Remove speaker cover.
  21. Disassembling Pentax Optio S4i Lens Assembly: paso 21, imagen 1 de 2 Disassembling Pentax Optio S4i Lens Assembly: paso 21, imagen 2 de 2
    • Turn camera to front.
    • Carefully peel off orange wire tape. The tape is glued to the surface indicated.
    • Lift speaker from holder.
  22. Disassembling Pentax Optio S4i Lens Assembly: paso 22, imagen 1 de 2 Disassembling Pentax Optio S4i Lens Assembly: paso 22, imagen 2 de 2
    • Use a wedge to lift up the wire tape flap.
  23. Disassembling Pentax Optio S4i Lens Assembly: paso 23, imagen 1 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 23, imagen 2 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 23, imagen 3 de 3
    • Insert the point of a spudger underneath the wire shown.
  24. Disassembling Pentax Optio S4i Lens Assembly: paso 24, imagen 1 de 2 Disassembling Pentax Optio S4i Lens Assembly: paso 24, imagen 2 de 2
    • Carefully lift the wire out of the crevasses.
  25. Disassembling Pentax Optio S4i Lens Assembly: paso 25, imagen 1 de 1
    • Slowly bend the speaker's wire tape away from the lens assembly. Avoid creasing the tape.
  26. Disassembling Pentax Optio S4i Lens Assembly: paso 26, imagen 1 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 26, imagen 2 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 26, imagen 3 de 3
    • Remove indicated screws:
    • Three Black 3.80mm Phillips #00 screws.
  27. Disassembling Pentax Optio S4i Lens Assembly: paso 27, imagen 1 de 2 Disassembling Pentax Optio S4i Lens Assembly: paso 27, imagen 2 de 2
    • Remove the indicated black 3.40mm Phillips #00 screw on the bottom of the camera.
    • Remove copper leads.
  28. Disassembling Pentax Optio S4i Lens Assembly: paso 28, imagen 1 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 28, imagen 2 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 28, imagen 3 de 3
    • Unscrew the indicated 3.80mm Phillips #00 screw on the back of the camera.
    • Remove screw and bracket.
  29. Disassembling Pentax Optio S4i Lens Assembly: paso 29, imagen 1 de 1
    • Turn the camera over to the front.
    • In the following step, you will undo the indicated pegs. PROCEED TO THE NEXT STEP.
  30. Disassembling Pentax Optio S4i Lens Assembly: paso 30, imagen 1 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 30, imagen 2 de 3 Disassembling Pentax Optio S4i Lens Assembly: paso 30, imagen 3 de 3
    • Carefully holding the camera, grab the corresponding two points.
    • Carefully twist the lens assembly away from you. You will be turning your hand clockwise.
    • Pull lens assembly out.
    • The lens assembly is attached to the logic board by wire tape.
Conclusión
Bassem Tossoun
Miembro Desde 01/21/11
201 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 4-29, Regan Winter 2011 Miembro de Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Miembros
10 Guías creadas
2 comentarios
Do you have this disassembly steps for the S12?
ThoH - Contestar
Lens will Not focuscorrectly
ThoH - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 2,261
