Saltar al contenido principal
Disassembling Pentax K200D Front Cover
Qué necesitas
  1. Disassembling Pentax K200D Front Cover, Preparation: paso 1, imagen 1 de 1
    • Retrieve your Pentax K200D, the lens mount cover, and required tools.
    • Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
  2. Disassembling Pentax K200D Front Cover, Flash: paso 2, imagen 1 de 1
    • With the camera turned on, press the pop-up flash button to release the flash.
    • Be sure to turn the camera back off before proceeding.
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  3. Disassembling Pentax K200D Front Cover, Bottom cover: paso 3, imagen 1 de 1
    • Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
    • Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
    • Open the battery door and carefully remove the bottom cover, as the battery door components become unsecured when the bottom cover is removed.
  4. Disassembling Pentax K200D Front Cover: paso 4, imagen 1 de 1
    • Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
Conclusión
9 personas más completaron esta guía.
Rick Nelson
Miembro Desde 06/05/10
706 Reputación
1 Guía escrita
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,545 Guías creadas
Un comentario
How do l clean the prisum…
brett_lorking - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 50
Todo El Tiempo: 6,378
