Saltar al contenido principal
Disassembling Panasonic GU87 Main Board removal
Qué necesitas
  1. Disassembling Panasonic GU87 Main Board removal, Battery: paso 1, imagen 1 de 1
    • Place your hands on the phone as shown in picture. Slightly pull the tab away from the phone with your thumb.
  2. Disassembling Panasonic GU87 Main Board removal: paso 2, imagen 1 de 1
    • Lift the battery up from the phone as shown. Replace with a new battery if the old battery has become worn out.
  3. Disassembling Panasonic GU87 Main Board removal, Disassembling Panasonic GU87 Back cover: paso 3, imagen 1 de 1
    • Remove the rubber covers with tweezers.
  4. Disassembling Panasonic GU87 Main Board removal: paso 4, imagen 1 de 1
    • Remove all 4 screws from the back of the phone.
  5. Disassembling Panasonic GU87 Main Board removal: paso 5, imagen 1 de 1
    • Use a plastic opening tool to separate the front and back casing.
  6. Disassembling Panasonic GU87 Main Board removal: paso 6, imagen 1 de 1
    • Put the tool in friction tabs and force down to open the cover as shown in the picture.
    • Carefully pop it open the rest of the way with your fingers.
  7. Disassembling Panasonic GU87 Main Board removal, Disassembling Panasonic GU87 Main Board removal: paso 7, imagen 1 de 1
    • Lift the main board over.
  8. Disassembling Panasonic GU87 Main Board removal: paso 8, imagen 1 de 1
    • Pry the connector with finger nails.
Conclusión
Van
Miembro Desde 06/24/10
7 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 2-10, Johann Summer 2010 Miembro de Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,743
