Saltar al contenido principal
Disassembling Palm Centro Logic Board
Qué necesitas
  1. Disassembling Palm Centro Logic Board, Disassembling Palm Centro Battery: paso 1, imagen 1 de 2 Disassembling Palm Centro Logic Board, Disassembling Palm Centro Battery: paso 1, imagen 2 de 2
    • Press and slide open the battery cover.
  2. Disassembling Palm Centro Logic Board: paso 2, imagen 1 de 1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Disassembling Palm Centro Logic Board: paso 3, imagen 1 de 1
    • Phone with battery removed
  4. Disassembling Palm Centro Logic Board, Back Housing: paso 4, imagen 1 de 1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Disassembling Palm Centro Logic Board: paso 5, imagen 1 de 1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Disassembling Palm Centro Logic Board: paso 6, imagen 1 de 2 Disassembling Palm Centro Logic Board: paso 6, imagen 2 de 2
    • Remove the SIM card so housing can be separated.
  7. Disassembling Palm Centro Logic Board: paso 7, imagen 1 de 2 Disassembling Palm Centro Logic Board: paso 7, imagen 2 de 2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Disassembling Palm Centro Logic Board: paso 8, imagen 1 de 2 Disassembling Palm Centro Logic Board: paso 8, imagen 2 de 2
    • Remove the small plastic insert at the bottom of the phone.
  9. Disassembling Palm Centro Logic Board: paso 9, imagen 1 de 2 Disassembling Palm Centro Logic Board: paso 9, imagen 2 de 2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Disassembling Palm Centro Logic Board, Logic Board: paso 10, imagen 1 de 1
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Disassembling Palm Centro Logic Board: paso 11, imagen 1 de 1
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Disassembling Palm Centro Logic Board: paso 12, imagen 1 de 1
    • Separate the logic board from the case by lifting and pulling out the bottom.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 15-49, Garner Spring 2010 Miembro de Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Miembros
12 Guías creadas
2 comentarios
note: if you need to replace the logic board, follow this guide, insert a new board, and then follow the steps in reverse order to get a working phone.
Chelsea Barackman - Contestar
i try to on this mobile ..but cant do that, i try to on this mobile so many ways.. i want to whhy thi mobile not on and how to resolve it?
kelumaruna - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 3,107
