Saltar al contenido principal
Disassembling Optoma HD20 Cover
Qué necesitas
  1. Disassembling Optoma HD20 Cover, Disassembling Optoma HD20 Cover: paso 1, imagen 1 de 2 Disassembling Optoma HD20 Cover, Disassembling Optoma HD20 Cover: paso 1, imagen 2 de 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Disassembling Optoma HD20 Cover: paso 2, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Disassembling Optoma HD20 Cover: paso 3, imagen 1 de 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Disassembling Optoma HD20 Cover: paso 4, imagen 1 de 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
Conclusión
8 personas más completaron esta guía.
Trever
Miembro Desde 01/22/15
1,264 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 21-23, Maness Winter 2015 Miembro de Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 18
Todo El Tiempo: 3,043
