Saltar al contenido principal
Olympus Stylus 725 SW LCD Screen Replacement
Qué necesitas
  1. Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Battery: paso 1, imagen 1 de 2 Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Battery: paso 1, imagen 2 de 2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Back Panel: paso 2, imagen 1 de 3 Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Back Panel: paso 2, imagen 2 de 3 Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Back Panel: paso 2, imagen 3 de 3
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
  3. Olympus Stylus 725 SW LCD Screen Replacement: paso 3, imagen 1 de 2 Olympus Stylus 725 SW LCD Screen Replacement: paso 3, imagen 2 de 2
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
  4. Olympus Stylus 725 SW LCD Screen Replacement, LCD Screen: paso 4, imagen 1 de 3 Olympus Stylus 725 SW LCD Screen Replacement, LCD Screen: paso 4, imagen 2 de 3 Olympus Stylus 725 SW LCD Screen Replacement, LCD Screen: paso 4, imagen 3 de 3
    • Remove the screws in the back panel using a Phillips #00 screwdriver.
    • Detach the ribbon cables that connect the LCD to the back panel of the camera.
  5. Olympus Stylus 725 SW LCD Screen Replacement: paso 5, imagen 1 de 2 Olympus Stylus 725 SW LCD Screen Replacement: paso 5, imagen 2 de 2
    • Use tweezers to remove the loosened LCD screen.
    • Be careful to not scratch the new LCD screen when replacing it.
    • Carefully place the new screen in place of the old, making sure the label faces up.
Conclusión
Una persona más ha completado esta guía.
Bobby Hodges
Miembro Desde 04/18/10
49 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 33-71, Johann Spring 2010 Miembro de Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 8,002
