Saltar al contenido principal
Disassembling Olympus Stylus 725 SW Front Panel
Qué necesitas
  1. Disassembling Olympus Stylus 725 SW Front Panel, Disassembling Olympus Stylus 725 SW Battery: paso 1, imagen 1 de 2 Disassembling Olympus Stylus 725 SW Front Panel, Disassembling Olympus Stylus 725 SW Battery: paso 1, imagen 2 de 2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Disassembling Olympus Stylus 725 SW Front Panel, Front Panel: paso 2, imagen 1 de 3 Disassembling Olympus Stylus 725 SW Front Panel, Front Panel: paso 2, imagen 2 de 3 Disassembling Olympus Stylus 725 SW Front Panel, Front Panel: paso 2, imagen 3 de 3
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
Conclusión
Bobby Hodges
Miembro Desde 04/18/10
49 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 33-71, Johann Spring 2010 Miembro de Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 3,236
