Saltar al contenido principal
Disassembling Olympus Stylus 725 SW Battery
  1. Disassembling Olympus Stylus 725 SW Battery, Disassembling Olympus Stylus 725 SW Battery: paso 1, imagen 1 de 2 Disassembling Olympus Stylus 725 SW Battery, Disassembling Olympus Stylus 725 SW Battery: paso 1, imagen 2 de 2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
Conclusión
Follow these instructions in reverse order to reassemble your device.
Bobby Hodges
Miembro Desde 04/18/10
49 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 33-71, Johann Spring 2010 Miembro de Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 33
Todo El Tiempo: 3,284
