Saltar al contenido principal
Olympus Stylus 410 Slider Replacement
Qué necesitas
  1. Olympus Stylus 410 Slider Replacement, Slider: paso 1, imagen 1 de 1
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Slider Replacement: paso 2, imagen 1 de 1
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Olympus Stylus 410 Slider Replacement: paso 3, imagen 1 de 1
    • Lift the slider up until it comes off the upper track.
  4. Olympus Stylus 410 Slider Replacement: paso 4, imagen 1 de 1
    • The slider should now be free from the body of the camera.
Conclusión
Una persona más ha completado esta guía.
Jared Ruekberg
Miembro Desde 04/15/10
33 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 6-13, Maness Spring 2010 Miembro de Cal Poly, Team 6-13, Maness Spring 2010
CPSU-MANESS-S10S6G13
5 Miembros
17 Guías creadas
2 comentarios
Camera would not turn on nor lens extend. Took slider off per instructions and cleaned the switch and was able to rotate switch back and forth to turn camera on and off by hand. Reassembled slider and could turn camera on but not off. Disassembled again and find the rotating switch is permanently stuck in counter clockwise position and cannot be activated by hand. I do not want to force the switch because it did operate very easy. What can be the trouble?
rraff8300@sbcglobal.net
Richard Rafferty - Contestar
Excellent instructions for removing stylist 410 slider. Hope you can help with my prior stuck switch problem.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 19
Todo El Tiempo: 3,545
