Saltar al contenido principal
Disassembling Olympus Stylus 1010 Case
Qué necesitas
  1. Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: paso 1, imagen 1 de 2 Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: paso 1, imagen 2 de 2
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Disassembling Olympus Stylus 1010 Case: paso 2, imagen 1 de 1
    • Remove the right side panel by pulling off the large silver piece.
  3. Disassembling Olympus Stylus 1010 Case: paso 3, imagen 1 de 2 Disassembling Olympus Stylus 1010 Case: paso 3, imagen 2 de 2
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Disassembling Olympus Stylus 1010 Case: paso 4, imagen 1 de 1
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Disassembling Olympus Stylus 1010 Case: paso 5, imagen 1 de 1
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Disassembling Olympus Stylus 1010 Case: paso 6, imagen 1 de 3 Disassembling Olympus Stylus 1010 Case: paso 6, imagen 2 de 3 Disassembling Olympus Stylus 1010 Case: paso 6, imagen 3 de 3
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Disassembling Olympus Stylus 1010 Case: paso 7, imagen 1 de 3 Disassembling Olympus Stylus 1010 Case: paso 7, imagen 2 de 3 Disassembling Olympus Stylus 1010 Case: paso 7, imagen 3 de 3
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
Conclusión
Una persona más ha completado esta guía.
Max McIntyre
Miembro Desde 01/21/11
526 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-4, Forte Winter 2011 Miembro de Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Miembros
12 Guías creadas
Un comentario
How did you get the ring around the lens off?? I can't seem to find that step and in all the pictures it's already off
Maureen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 3,021
