Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Instrucciones de Vídeo
Conclusión
To reassemble your device, follow the entire video
26 personas más completaron esta guía.
LE55ONS
Miembro Desde 30/05/12
10,977 Reputación
6 Guías creadas
okay number one this dude is not wearing gloves.2 hes rough with this phone
good work taking apart
roland wal - Contestar
In my case the headphone jack was glued with doublesided tape to the rear bezel instead of just loosely attached to the display assembly. And the process of getting the display assembly out of the bezel was more difficult than shown in the video. But I successfully swapped my audio jack thanks to this disassembly guide.
Constantin Becker - Contestar
I replaced the cracked screen digitizer and lcd with the help of this video successfully.
Thank you.
Bruce - Contestar
My lumia 920 have audio problems. It all started when i used Samsung's earplug. Since then my phone was permanently on headphone mode but none of the headphones worked and after removing my headphone my audio stopped working. I did factory reset but problem still persisted. I disconnected my audio jack from the phone and phone was working fine for few days,but again same problem came,i.e. No audio output/input and speaker stopped working along with error code "c00d36c4". I have factory reset my phone many times but it is not working.
I have searched all over the Internet but no soln is provided. Can anyone help me? Please provide me the parts info that i should change to fix it.
Adnan Nabi - Contestar
Use a qtip - pull off the majority of the cotton, dip in alcohol, insert and spin to clean - there is a small pin in the earplug that activates headphone mode. cleaning helped release the pin on mine.
Jason Horton -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 132,079
