Saltar al contenido principal
Disassembling Nokia E61i Microphone
Qué necesitas
  1. Disassembling Nokia E61i Microphone, Battery: paso 1, imagen 1 de 2 Disassembling Nokia E61i Microphone, Battery: paso 1, imagen 2 de 2
    • First, gather all necessary tools.
    • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing down on the tab.
  2. Disassembling Nokia E61i Microphone: paso 2, imagen 1 de 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Disassembling Nokia E61i Microphone: paso 3, imagen 1 de 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Disassembling Nokia E61i Microphone, Front Cover: paso 4, imagen 1 de 2 Disassembling Nokia E61i Microphone, Front Cover: paso 4, imagen 2 de 2
    • To remove the top of the back cover, pry the sides and pop it off.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Disassembling Nokia E61i Microphone: paso 5, imagen 1 de 1
    • Remove the cover by pulling it up and off.
  6. Disassembling Nokia E61i Microphone, Display: paso 6, imagen 1 de 2 Disassembling Nokia E61i Microphone, Display: paso 6, imagen 2 de 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon, disconnecting contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Disassembling Nokia E61i Microphone: paso 7, imagen 1 de 2 Disassembling Nokia E61i Microphone: paso 7, imagen 2 de 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Disassembling Nokia E61i Microphone, Motherboard: paso 8, imagen 1 de 3 Disassembling Nokia E61i Microphone, Motherboard: paso 8, imagen 2 de 3 Disassembling Nokia E61i Microphone, Motherboard: paso 8, imagen 3 de 3
    • Pull the green motherboard from the back casing.
  9. Disassembling Nokia E61i Microphone, Connector Housing: paso 9, imagen 1 de 1
    • Remove the connector housing by pushing and sliding it off the back panel.
    • Be very careful not to lose the small loose spring from behind the button or the small button itself.
  10. Disassembling Nokia E61i Microphone, Microphone: paso 10, imagen 1 de 1
    • After the connector housing has been removed, there is nothing else holding the microphone in place. Simply remove it from the housing by pulling up.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 9-63, Walters Spring 2011 Miembro de Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
Miembros de 5
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 2,377
