Saltar al contenido principal
Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly
Qué necesitas
  1. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Battery: paso 1, imagen 1 de 2 Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Battery: paso 1, imagen 2 de 2
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: paso 2, imagen 1 de 1
    • To remove the battery, push it down from the top and pull it out.
  3. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: paso 3, imagen 1 de 1
    • Grip the front cover from the bottom.
  4. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: paso 4, imagen 1 de 1
    • Lift the front cover off.
  5. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: paso 5, imagen 1 de 1
    • Remove the six screws using a T6 torx screwdriver.
  6. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: paso 6, imagen 1 de 1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: paso 7, imagen 1 de 1
    • Remove assembly from phone
Conclusión
Colby Leslie
Miembro Desde 10/05/10
1 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 22-3, Maness Fall 2010 Miembro de Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,055
