Introducción
This guide will help you remove the front casing.
Herramientas
Partes
No se especificaron partes.
Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone.
Lift the battery case off of the phone.
Once you have removed the battery, pull the tab on the metal sim card cover, and lift it up.
The sim card is underneath and can now be removed.
Locate the notch on the bottom right corner of the phone.
Beginning at this point, slide the head of the screwdriver between the front casing and the rest of the phone.
Continue to slide the screwdriver towards the top edge of the phone.
The front casing should eventually pop off.
