Saltar al contenido principal
Disassembling Nokia 3560 Vibrator
Qué necesitas
  1. Disassembling Nokia 3560 Vibrator, Back Cover: paso 1, imagen 1 de 2 Disassembling Nokia 3560 Vibrator, Back Cover: paso 1, imagen 2 de 2
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Keypad: paso 2, imagen 1 de 1
    • Lift the front case off of the phone body.
  3. Disassembling Nokia 3560 Vibrator: paso 3, imagen 1 de 2 Disassembling Nokia 3560 Vibrator: paso 3, imagen 2 de 2
    • Lift the keypad off of the phone.
  4. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 LCD Display: paso 4, imagen 1 de 1
    • The screen is held to the body by six screws.
  5. Disassembling Nokia 3560 Vibrator: paso 5, imagen 1 de 1
    • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  6. Disassembling Nokia 3560 Vibrator: paso 6, imagen 1 de 2 Disassembling Nokia 3560 Vibrator: paso 6, imagen 2 de 2
    • Insert a flat screwdriver between the black body and plastic layer.
  7. Disassembling Nokia 3560 Vibrator: paso 7, imagen 1 de 1
    • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  8. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Logic Board: paso 8, imagen 1 de 1
    • With the screws removed, the logic board can then be lifted out of the body by hand.
  9. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Vibrator: paso 9, imagen 1 de 2 Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Vibrator: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    • The orange piece is the vibrator.
    • It is not fastened by any means.
    • Remove with tweezers.
Conclusión
Sam Ryan
Miembro Desde 04/18/10
1 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 30-39, Garner Spring 2010 Miembro de Cal Poly, Team 30-39, Garner Spring 2010
CPSU-GARNER-S10S30G39
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 18
Todo El Tiempo: 1,320
