Saltar al contenido principal
Disassembling Nokia 3395 Logic Board
Qué necesitas
  1. Disassembling Nokia 3395 Logic Board, Back Case: paso 1, imagen 1 de 3 Disassembling Nokia 3395 Logic Board, Back Case: paso 1, imagen 2 de 3 Disassembling Nokia 3395 Logic Board, Back Case: paso 1, imagen 3 de 3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
  2. Disassembling Nokia 3395 Logic Board, Battery: paso 2, imagen 1 de 2 Disassembling Nokia 3395 Logic Board, Battery: paso 2, imagen 2 de 2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
  3. Disassembling Nokia 3395 Logic Board, Front Case: paso 3, imagen 1 de 2 Disassembling Nokia 3395 Logic Board, Front Case: paso 3, imagen 2 de 2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
  4. Disassembling Nokia 3395 Logic Board, Screen: paso 4, imagen 1 de 2 Disassembling Nokia 3395 Logic Board, Screen: paso 4, imagen 2 de 2
    • Remove six T6 screws.
  5. Disassembling Nokia 3395 Logic Board: paso 5, imagen 1 de 2 Disassembling Nokia 3395 Logic Board: paso 5, imagen 2 de 2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
  6. Disassembling Nokia 3395 Logic Board, Logic Board: paso 6, imagen 1 de 2 Disassembling Nokia 3395 Logic Board, Logic Board: paso 6, imagen 2 de 2
    • Remove logic board as shown.
Conclusión
3 personas más completaron esta guía.
Nico Lee
Miembro Desde 04/19/10
83 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 30-41, Garner Spring 2010 Miembro de Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 1,940
