Saltar al contenido principal
Disassembling Nokia 3395 Inner Components
Qué necesitas
  1. Disassembling Nokia 3395 Inner Components, Back Case: paso 1, imagen 1 de 3 Disassembling Nokia 3395 Inner Components, Back Case: paso 1, imagen 2 de 3 Disassembling Nokia 3395 Inner Components, Back Case: paso 1, imagen 3 de 3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
  2. Disassembling Nokia 3395 Inner Components, Battery: paso 2, imagen 1 de 2 Disassembling Nokia 3395 Inner Components, Battery: paso 2, imagen 2 de 2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
  3. Disassembling Nokia 3395 Inner Components, Front Case: paso 3, imagen 1 de 2 Disassembling Nokia 3395 Inner Components, Front Case: paso 3, imagen 2 de 2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
  4. Disassembling Nokia 3395 Inner Components, Screen: paso 4, imagen 1 de 2 Disassembling Nokia 3395 Inner Components, Screen: paso 4, imagen 2 de 2
    • Remove six T6 screws.
  5. Disassembling Nokia 3395 Inner Components: paso 5, imagen 1 de 2 Disassembling Nokia 3395 Inner Components: paso 5, imagen 2 de 2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
  6. Disassembling Nokia 3395 Inner Components, Logic Board: paso 6, imagen 1 de 2 Disassembling Nokia 3395 Inner Components, Logic Board: paso 6, imagen 2 de 2
    • Remove logic board as shown.
  7. Disassembling Nokia 3395 Inner Components, Inner Components: paso 7, imagen 1 de 1
    • Use the following legend to locate each component:
    • Microphone/power assembly.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    • Power toggle button.
    • Battery connector.
  8. Disassembling Nokia 3395 Inner Components: paso 8, imagen 1 de 2 Disassembling Nokia 3395 Inner Components: paso 8, imagen 2 de 2
    • Insert spudger between power assembly/micro-phone and phone body.
    • Pry as shown and remove the power assembly/microphone.
  9. Disassembling Nokia 3395 Inner Components: paso 9, imagen 1 de 1
    • Once located, the following components are easily removed by pulling them out with your hand.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
  10. Disassembling Nokia 3395 Inner Components: paso 10, imagen 1 de 2 Disassembling Nokia 3395 Inner Components: paso 10, imagen 2 de 2
    • Audio speaker.
  11. Disassembling Nokia 3395 Inner Components: paso 11, imagen 1 de 2 Disassembling Nokia 3395 Inner Components: paso 11, imagen 2 de 2
    • SIM card reader.
  12. Disassembling Nokia 3395 Inner Components: paso 12, imagen 1 de 2 Disassembling Nokia 3395 Inner Components: paso 12, imagen 2 de 2
    • Vibrating unit.
  13. Disassembling Nokia 3395 Inner Components: paso 13, imagen 1 de 2 Disassembling Nokia 3395 Inner Components: paso 13, imagen 2 de 2
  14. Disassembling Nokia 3395 Inner Components: paso 14, imagen 1 de 2 Disassembling Nokia 3395 Inner Components: paso 14, imagen 2 de 2
Conclusión
Una persona más ha completado esta guía.
Nico Lee
Miembro Desde 04/19/10
83 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 30-41, Garner Spring 2010 Miembro de Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 2,974
