Saltar al contenido principal
Introducción
This guide is a step by step procedure to disassemble the base of the phone. It is the preliminary step in gaining access to the inner components of the Nokia 2366i.
  1. Turn off the phone. Position the phone so that the back side is in view.
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Apply pressure on the cover while simultaneously sliding the cover downward.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Insert the spudger between the base of the phone and the phone battery. Position the phone so that the battery won't fall out of the phone. Carefully lift the battery out of the phone.
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone. Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
    • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
  6. Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver: 2 screws at the bottom
    • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
    • 2 screws at the bottom
    • 2 screws at the top
  7. Rotate the phone clockwise so the edge is facing you. Insert the spudger in tabs between the outer casing and the inside frame.
    • Rotate the phone clockwise so the edge is facing you.
    • Insert the spudger in tabs between the outer casing and the inside frame.
    • Slide the spudger upwards.
    • This will remove the rear case of the phone.
  8. The phone should now be in two different sections.
    • The phone should now be in two different sections.
    • 1) The rear case of the phone.
    • 2) The motherboard and the rest of the phone.
Conclusión
Una persona más ha completado esta guía.
Jonathan Newman
Miembro Desde 21/01/11
486 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 1-14, Amido Winter 2011 Miembro de Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,438
