Introducción
Removing a broken front display.
Partes
No se requieren partes.
  1. Turn off the phone. Position the phone so that the back side is in view.
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Apply pressure on the cover while simultaneously sliding the cover downward.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Insert the spudger between the base of the phone and the phone battery. Position the phone so that the battery won't fall out of the phone. Carefully lift the battery out of the phone.
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Keep the phone closed.
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Find the slight crease on the side that divides the display assembly in half. Slowly wedge the spudger into the crease.
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  7. Run the spudger all along the crease while lifting up. Separate the front cover from the front base.
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
  8. Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver. Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
    • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
  9. Using the spudger, disconnect the green display cable. Using the spudger, disconnect the green display cable.
    • Using the spudger, disconnect the green display cable.
  10. Lift the metal casing. Be careful not to pull the casing too hard because it is still attached to the phone by a wire. Remove the main display from under the metal casing.
    • Lift the metal casing.
    • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
    • Remove the main display from under the metal casing.
  11. Fold the metal casing back over. Disconnect the orange front display data cable with the spudger. Hold the phone so that the antenna is facing towards you.
    • Fold the metal casing back over.
    • Disconnect the orange front display data cable with the spudger.
    • Hold the phone so that the antenna is facing towards you.
    • Lift up and flip over the metal casing.
  12. Using your fingers, remove the front display.
    • Using your fingers, remove the front display.
Conclusión
Michael Machado
Miembro Desde 21/01/11
334 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 1-14, Amido Winter 2011 Miembro de Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 840
