Saltar al contenido principal
Disassembling Nokia 2366i Front Cover
Qué necesitas
  1. Disassembling Nokia 2366i Front Cover, Battery: paso 1, imagen 1 de 2 Disassembling Nokia 2366i Front Cover, Battery: paso 1, imagen 2 de 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Front Cover: paso 2, imagen 1 de 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Front Cover: paso 3, imagen 1 de 3 Disassembling Nokia 2366i Front Cover: paso 3, imagen 2 de 3 Disassembling Nokia 2366i Front Cover: paso 3, imagen 3 de 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Front Cover, Front Cover: paso 4, imagen 1 de 1
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. Disassembling Nokia 2366i Front Cover: paso 5, imagen 1 de 2 Disassembling Nokia 2366i Front Cover: paso 5, imagen 2 de 2
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  6. Disassembling Nokia 2366i Front Cover: paso 6, imagen 1 de 2 Disassembling Nokia 2366i Front Cover: paso 6, imagen 2 de 2
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
Conclusión
Una persona más ha completado esta guía.
Kristen
Miembro Desde 01/17/11
175 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 1-14, Amido Winter 2011 Miembro de Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 1,170
