Saltar al contenido principal
Disassembling Nintendo DSi Bottom case
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
    Disassembling Nintendo DSi Bottom case, Battery: paso 1, imagen 1 de 1
    • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
  2. Disassembling Nintendo DSi Bottom case: paso 2, imagen 1 de 1
    • L Button.
    • Top of the battery pack.
    • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
  3. Aviso: los pasos 3-4 provienen de una guía que está marcada como "En progreso".
    Disassembling Nintendo DSi Bottom case, Motherboard: paso 3, imagen 1 de 2 Disassembling Nintendo DSi Bottom case, Motherboard: paso 3, imagen 2 de 2
    • Remove 4 Phillips screws from the board.
    • Lift the main board from the bottom end and flip it over to reveal the last connector.
    • Keep the main board fairly close to the case, making sure not to damage the last ribbon cable holding it in place.
  4. Disassembling Nintendo DSi Bottom case: paso 4, imagen 1 de 1
    • Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
    • The motherboard should now be free from the rest of the device.
  5. Disassembling Nintendo DSi Bottom case, Disassembling Nintendo DSi Bottom case: paso 5, imagen 1 de 1
    • Remove the rubber front-panel button membranes from the device. Pay careful attention to where the buttons go, so you can replace them correctly.
    • A/B/X/Y button assembly
    • Select/Start button assembly
    • D-pad
    • Power button
  6. Disassembling Nintendo DSi Bottom case: paso 6, imagen 1 de 2 Disassembling Nintendo DSi Bottom case: paso 6, imagen 2 de 2
    • Remove the plastic buttons and keep them in a safe place.
    • All of the buttons have "key" notches to prevent them from being inserted incorrectly (backwards or in the wrong place), but it can take a while to figure out where everything goes if they get shuffled around.
  7. Disassembling Nintendo DSi Bottom case: paso 7, imagen 1 de 2 Disassembling Nintendo DSi Bottom case: paso 7, imagen 2 de 2
    • Flip the case open, and push the lower screen assembly out of the frame.
Conclusión
rjcamero
Miembro Desde 11/05/09
50 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 6-1, Maness Fall 2009 Miembro de Cal Poly, Team 6-1, Maness Fall 2009
CPSU-MANESS-F09S6G1
5 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 5,351
