Saltar al contenido principal
Disassembling Nikon Coolpix 5600 Flash Unit
Qué necesitas
  1. Disassembling Nikon Coolpix 5600 Flash Unit, Remove Screws: paso 1, imagen 1 de 3 Disassembling Nikon Coolpix 5600 Flash Unit, Remove Screws: paso 1, imagen 2 de 3 Disassembling Nikon Coolpix 5600 Flash Unit, Remove Screws: paso 1, imagen 3 de 3
    • Remove the screws from the bottom, right, and left side of camera.
  2. Disassembling Nikon Coolpix 5600 Flash Unit, Remove back: paso 2, imagen 1 de 1
    • Remove the back of the camera, this may require force.
  3. Disassembling Nikon Coolpix 5600 Flash Unit, Remove Metal Bracket: paso 3, imagen 1 de 1
    • Unscrew the right metal bracket of the viewing lens
  4. Disassembling Nikon Coolpix 5600 Flash Unit, Remove front of camera: paso 4, imagen 1 de 1
    • Unscrew the top right corner screw
  5. Disassembling Nikon Coolpix 5600 Flash Unit: paso 5, imagen 1 de 1
    • Unscrew the bottom right corner screw.
  6. Disassembling Nikon Coolpix 5600 Flash Unit: paso 6, imagen 1 de 2 Disassembling Nikon Coolpix 5600 Flash Unit: paso 6, imagen 2 de 2
    • Pull the grey circular facet that sits on the bottom outside of the camera off - may have to use force.
  7. Disassembling Nikon Coolpix 5600 Flash Unit: paso 7, imagen 1 de 2 Disassembling Nikon Coolpix 5600 Flash Unit: paso 7, imagen 2 de 2
    • Pull the front of the camera off of the mother board.
  8. Disassembling Nikon Coolpix 5600 Flash Unit, Disassembling Nikon Coolpix 5600 Flash Unit: paso 8, imagen 1 de 1
    • Unscrew the grey plastic around the screen
  9. Disassembling Nikon Coolpix 5600 Flash Unit: paso 9, imagen 1 de 1
    • Twist the grey bracket counterclockwise to remove it from the silver LCD bracket.
  10. Disassembling Nikon Coolpix 5600 Flash Unit: paso 10, imagen 1 de 1
    • Maneuver to detach the flash bulb.
  11. Disassembling Nikon Coolpix 5600 Flash Unit: paso 11, imagen 1 de 1
    • Unscrew the metal bracket under the lens
  12. Disassembling Nikon Coolpix 5600 Flash Unit: paso 12, imagen 1 de 1
    • Slide the plastic bracket through the metal bracket.
    • Remove the orange cable from the motherboard.
  13. Disassembling Nikon Coolpix 5600 Flash Unit: paso 14, imagen 1 de 1
    • Pull the black tape off.
  14. Disassembling Nikon Coolpix 5600 Flash Unit: paso 15, imagen 1 de 1
    • Unscrew the two screws underneath.
    • Remove lens
Conclusión
Una persona más ha completado esta guía.
Crista Riedy
Miembro Desde 02/12/13
406 Reputación
3 Guías creadas
Equipo
Ohio State, Team 1-2, Buehl Spring 2013 Miembro de Ohio State, Team 1-2, Buehl Spring 2013
OSU-BUEHL-S13S1G2
2 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 758
