Saltar al contenido principal
Disassembling NEC LCD1770NX Monitor Enclosure
Qué necesitas
  1. Disassembling NEC LCD1770NX Monitor Enclosure, Stand: paso 1, imagen 1 de 2 Disassembling NEC LCD1770NX Monitor Enclosure, Stand: paso 1, imagen 2 de 2
    • Place the monitor face down on a clean, flat surface.
  2. Disassembling NEC LCD1770NX Monitor Enclosure: paso 2, imagen 1 de 2 Disassembling NEC LCD1770NX Monitor Enclosure: paso 2, imagen 2 de 2
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. Disassembling NEC LCD1770NX Monitor Enclosure: paso 3, imagen 1 de 2 Disassembling NEC LCD1770NX Monitor Enclosure: paso 3, imagen 2 de 2
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. Disassembling NEC LCD1770NX Monitor Enclosure: paso 4, imagen 1 de 2 Disassembling NEC LCD1770NX Monitor Enclosure: paso 4, imagen 2 de 2
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. Disassembling NEC LCD1770NX Monitor Enclosure: paso 5, imagen 1 de 1
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. Disassembling NEC LCD1770NX Monitor Enclosure: paso 6, imagen 1 de 2 Disassembling NEC LCD1770NX Monitor Enclosure: paso 6, imagen 2 de 2
    • Lift the the stand straight up to remove it.
  7. Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: paso 7, imagen 1 de 3 Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: paso 7, imagen 2 de 3 Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: paso 7, imagen 3 de 3
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  8. Disassembling NEC LCD1770NX Monitor Enclosure: paso 8, imagen 1 de 3 Disassembling NEC LCD1770NX Monitor Enclosure: paso 8, imagen 2 de 3 Disassembling NEC LCD1770NX Monitor Enclosure: paso 8, imagen 3 de 3
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  9. Disassembling NEC LCD1770NX Monitor Enclosure: paso 9, imagen 1 de 2 Disassembling NEC LCD1770NX Monitor Enclosure: paso 9, imagen 2 de 2
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  10. Disassembling NEC LCD1770NX Monitor Enclosure: paso 10, imagen 1 de 1
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  11. Disassembling NEC LCD1770NX Monitor Enclosure: paso 11, imagen 1 de 3 Disassembling NEC LCD1770NX Monitor Enclosure: paso 11, imagen 2 de 3 Disassembling NEC LCD1770NX Monitor Enclosure: paso 11, imagen 3 de 3
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  12. Disassembling NEC LCD1770NX Monitor Enclosure: paso 12, imagen 1 de 2 Disassembling NEC LCD1770NX Monitor Enclosure: paso 12, imagen 2 de 2
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  13. Disassembling NEC LCD1770NX Monitor Enclosure: paso 13, imagen 1 de 2 Disassembling NEC LCD1770NX Monitor Enclosure: paso 13, imagen 2 de 2
    • Pull the the metal casing off of the monitor to reveal the motherboards.
Conclusión
2 personas más completaron esta guía.
John Patterson
Miembro Desde 10/19/13
253 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-36, Amido Fall 2013 Miembro de Cal Poly, Team 11-36, Amido Fall 2013
CPSU-AMIDO-F13S11G36
5 Miembros
7 Guías creadas
Un comentario
very helpful
Thank you
Richard Morgan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 31
Todo El Tiempo: 5,793
