Introducción
This guide details how to remove the logic board.
  1. Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it.
    • Slide the notch downward while pulling the back cover off to remove it.
  2. Use your fingers to push the battery upward from the bottom. Lift upwards to remove the battery. Lift upwards to remove the battery.
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
  3. Unscrew the antenna in a counter-clockwise fashion. Remove the aluminum cover.
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Unscrew the 3 screws shown. Lift up the right part of the Nextel logo and unscrew the screw underneath. Lift up the right part of the Nextel logo and unscrew the screw underneath.
    • Unscrew the 3 screws shown.
    • Lift up the right part of the Nextel logo and unscrew the screw underneath.
  6. DO NOT force the cover off as it could damage the ribbon cable! Gently lift the back cover off.
    • DO NOT force the cover off as it could damage the ribbon cable!
    • Gently lift the back cover off.
  7. Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board.
    • Carefully pry off the connection between the headphone jack and logic board.
  8. Lift the first logic board off of the rest of the device. Lift the first logic board off of the rest of the device.
    • Lift the first logic board off of the rest of the device.
  9. Gently lift the second logic board from the rest of the device.
    • Gently lift the second logic board from the rest of the device.
    • DO NOT force the board straight off as it could damage the ribbon cable!
  10. Using tweezers, carefully pull off the connector shown. Using tweezers, carefully pull off the connector shown.
    • Using tweezers, carefully pull off the connector shown.
Conclusión
Equipo
Cal Poly, Team 29-61, Johann Spring 2010 Miembro de Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 895
