Saltar al contenido principal
Disassembling Motorola i850 Keypad
Qué necesitas
  1. Disassembling Motorola i850 Keypad, Disassembling Motorola i850 Back Cover: paso 1, imagen 1 de 1
    • Use your thumb to slide the back cover locker away from the antenna.
  2. Disassembling Motorola i850 Keypad: paso 2, imagen 1 de 2 Disassembling Motorola i850 Keypad: paso 2, imagen 2 de 2
    • Slide the back cover towards the antenna while lifting the cover away from the phone.
  3. Disassembling Motorola i850 Keypad, Battery: paso 3, imagen 1 de 1
    • Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
  4. Disassembling Motorola i850 Keypad: paso 4, imagen 1 de 2 Disassembling Motorola i850 Keypad: paso 4, imagen 2 de 2
    • Lift the battery out of the phone while pushing it towards the antenna.
  5. Disassembling Motorola i850 Keypad, Keypad: paso 5, imagen 1 de 1
    • Once battery is removed, untighten the screws located near the edges of the device with a Phillips #00 Screwdriver.
  6. Disassembling Motorola i850 Keypad: paso 6, imagen 1 de 3 Disassembling Motorola i850 Keypad: paso 6, imagen 2 de 3 Disassembling Motorola i850 Keypad: paso 6, imagen 3 de 3
    • Grip the device firmly with both hands and carefully open the device.
    • Warning: Interior hardware inside the device can be easily damaged.
  7. Disassembling Motorola i850 Keypad: paso 7, imagen 1 de 2 Disassembling Motorola i850 Keypad: paso 7, imagen 2 de 2
    • Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer.
  8. Disassembling Motorola i850 Keypad: paso 8, imagen 1 de 2 Disassembling Motorola i850 Keypad: paso 8, imagen 2 de 2
    • Carefully grip the side of the hardware attachment with a tweezer and detach from device.
  9. Disassembling Motorola i850 Keypad: paso 9, imagen 1 de 3 Disassembling Motorola i850 Keypad: paso 9, imagen 2 de 3 Disassembling Motorola i850 Keypad: paso 9, imagen 3 de 3
    • Place the back of the device on your hand and flip it over with the other hand.
    • Carefully lift the device to remove interior hardware.
    • The structure of the keypad should easily be loose from flipping the device.
  10. Disassembling Motorola i850 Keypad: paso 10, imagen 1 de 3 Disassembling Motorola i850 Keypad: paso 10, imagen 2 de 3 Disassembling Motorola i850 Keypad: paso 10, imagen 3 de 3
    • Carefully remove the keypad by griping on the side of the plastic with a tweezer.
    • WARNING: The plastic keypad is sensitive and can be easily damaged.
Conclusión
Tony Chen
Miembro Desde 04/08/10
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 34-56, Forte Spring 2010 Miembro de Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,664
