Saltar al contenido principal
Motorola V180 Connector Ribbon Replacement
Qué necesitas
  1. Motorola V180 Connector Ribbon Replacement, Connector Ribbon: paso 1, imagen 1 de 1
    • Gently tug on the upper edge of the faceplate, and it will easily detach.
  2. Motorola V180 Connector Ribbon Replacement: paso 2, imagen 1 de 1
    • Remove the four screws securing the front cover.
  3. Motorola V180 Connector Ribbon Replacement: paso 3, imagen 1 de 1
    • Gently glide the metallic silver cover outward.
    • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
  4. Motorola V180 Connector Ribbon Replacement: paso 4, imagen 1 de 1
    • Insert a pair of tweezers between the silver and black sections of the cover.
    • The silver section should now easily snap away.
  5. Motorola V180 Connector Ribbon Replacement: paso 5, imagen 1 de 1
    • The black rubber component can now easily be taken off.
  6. Motorola V180 Connector Ribbon Replacement: paso 6, imagen 1 de 1
    • Use a soldering iron to detach the connector ribbon from the phone.
Conclusión
Tyler Knisley
Miembro Desde 05/07/10
1 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 6-16, Maness Spring 2010 Miembro de Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 2,613
